33 -
Afisare la bord Anti-Skid Service Required
tweety replied to montreal10's topic in VOLVO S60/S60R (2001-2009)
buna aceeasi problema am avut-o si eu dar am rezolvat-o am dus calculatorul de la diferential la un electrician si i-a dat un aer cald ca sa se refaca lipiturile iar de atunci nu mai am nici o problema totul este ok -
tweety started following Afisare la bord Anti-Skid Service Required
cred ca am gasit problema IMPORTANT RECALL NOTICE May 25, 2007 To all Volvo Retailers and Employees: RE: Recall 181, certain model year(s) 2003-2004 S60/V70 Fuel Pressure Sensors Volvo Cars of North America, LLC (Volvo) has notified the National Highway Traffic Safety Administration and Transport Canada that we will perform a Voluntary Safety Recall to replace the Fuel Pressure Sensor on certain model year 2003 and 2004 Volvo S60/V70 vehicles. The fuel pressure sensor (FPS) located on the left side of the fuel rail, may at times transmit incorrect signals regarding the fuel pressure to the Engine Control Module (ECM). If the signal is outside of the pre-programmed allowable limits, a Diagnostic Trouble Code (DTC) may be set and the Check Engine Light (CEL) will come on. Engine misfire may occur during driving that in turn can reduce the engine torque, in the worst case scenario the engine may stall without warning. GOVERNMENT NOTIFICATION: As required, Volvo has notified the United States Government that it is preparing to launch Recall 181. CUSTOMER INQUIRIES: As you know, the current state of media and Internet technology can bring immediate attention and public awareness of Recalls. We are sending you this information before formally launching this Recall so that you will be prepared for customer inquiries. If you are unable to answer a customer's inquiry direct them to: Volvo Customer Care 800-458-1552 RECALL DESCRIPTION: • 2003 and 2004 Volvo S60 and V70 vehicles with the following engines (codes): o B5244S (61), B5244S6 (64), B5254T4 (52) B5254T2 (59) CORRECTIVE ACTION: Vehicle owners will receive a letter via first class mail and will be advised to contact their retailer for an appointment. The Fuel Pressure Sensor will be replaced at no charge to the customer. If you have any questions concerning this information, please contact me at 201-768-7300 extension 7908 (akopstei@volvocars.com) Regards, Adam Kopstein Manager, Automotive Safety & Compliance
buna am mai luat un senzor nou ,o pompa noua si presiunea in relantiu este de 2 bari si fluctueaza ce nu intzele este ca pompa baga 7.5 bari dar pe pe returul din rezervor nu curge benzina numai cand pun contactul inca o chestie interesanta e faptul ca daca scot mufa de la senzorul de presiune imi urca presinea la 7 bari poate mai imi dati o idee va multumesc
tweety started following vand amortizoare second volvo s60r
pompa de 2.5 t
am schimbat si supapa by-pass si tot degeaba acuma ii pusa a 3-a pompa deci cred ca si aia ar trebui exclusa
in relanti am presiunea corespunzatoare da in turatie scade intre 2 si 3 dar nu tot timpul masina trage bine si doar f rar simt unele intreruperi
la mine valva by-pass ii pe capacul pompei de benzina si deschide la 4.5 bari am sa caut alt capac undeva sa vad at care ii treaba va multumesc deocamdata
pompa a fost schimbata conducta de la pompa la rampa ii ok filtrul ii nou supapa de presiune din rezervor deschide la 4.5 bari ce nu intzeleg eu este dc daca pun barometrul la rampa nu am suficienta presiune ii posibil sa fie si ecm dar curentul la pompa imi vine constant na am caderi de tensiune sa scada turatia pompei
am pus si senzor nou si ii acelasi lucru
senzorul l-am luat de la alex din zalau el a ziss ca ii ok azi am comandat unul nou cred ca pe sambata vine iar volorile nu is ok in turatie nu are presiune suficienta ii prea mica presiunea in relanti ii ok
senzor presiune combustibil
am schimbat senzorul am schimbat si pompa de benzina dar masina face din nou la fel am fost si la reprezentanta si nu stie nimeni care ar putea fi problema de la PWG din cj mi-au ziss ca ar putea fi din soft sau calculatorul de la pompa deci inca problema nu am rezolvato am uitat sa va zic ca pompa si senzorul le-am pus second
ok te caut dupa sarbatori ms mult sarbarori fericite
Îmi poți da codul de pe ea si un preț Ms mult
cumpar pompa benzina volvo s60r
