MAIDRAGA
    14
Everything posted by MAIDRAGA
  1. Coduri erori
    Salut Luni dimineata m-am programat la Volvo Cj pentru update de soft si eventual o diagnoza. Intre timp am facut rost de o mufa bluetooth OBD II, am instalat aplicatia torque pe tableta sa pot citi coduri daca am. Am gasit 8 coduri: P1577 P2585 U0405 P193b P1187 U300b U0167 P0234 Daca cineva ma paote ajuta sa fiu pregatit pe cand ajung la Volvo, va rog nu ezitati.
  2. Coduri erori
    Uit sa intru pe forum, cu lunile. Desi am cont, cum nu sunt un obisnuit al forumului, intru doar cand imi aduc aminte ca exista aceasta comunitate si membrii cu aceleasi probleme ca ale mele.
  3. Coduri erori
    Am fost azi la Volvo. Am o lista de erori de la 48 incoace. Dupa update-ul de soft facut azi si cu masina in proba( cu ei) nu au mai aparut, dar ma indoiesc ca problema de presiune la turbo va disparea peste noapte. Control Module - Diagnostic Trouble Code Status ADM - No fault found AUD - No fault found BCM-0101 Communication between control units Communicational problems with ECM DTC is found active. CCM-0060 Damper motor, defroster Internal fault DTC is found not active. CCM-0062 Damper motor, temperature left Internal fault DTC is found not active. CCM-DD15 Damper motor, temperature left No communication DTC is found not active. CCM-DD16 Damper motor distribution No communication DTC is found not active. CCM-DD31 Damper motor, recirculation. No communication DTC is found not active. CCM-DD32 Damper motor, temperature right No communication DTC is found not active. CCM-DD33 Damper motor, defroster No communication DTC is found not active. CEM-4C01 Ambient temperature sensor Signal too high DTC is found not active. CEM-4F33 Battery Temperature Faulty Signal DTC is found not active. CEM-8A12 Low beam left Faulty signal DTC is found not active. CEM-8F22 Wiper motor module (WMM) Voltage too low DTC is found not active. CEM-DF11 CAN-H, high speed network Signal missing DTC is found not active. CEM-4C02 Ambient temperature sensor Signal too low DTC is found not active. CEM-DE43 Communication with DOM control module Signal missing DTC is found not active. CEM-6C15 Double lock, left rear door Lock failure DTC is found not active. CPM-4001 Auxiliary heater Activated too long DTC is found not active. DDM-6E03 Mirror motor Open circuit DTC is found not active. DDM-6E0S Mirror motor Open circuit DTC is found not active. DDM-6E0C Mirror motor Open circuit DTC is found not active. DDM-8003 Mirror heater Open circuit or shorted to supply DTC is found not active. DDM-8022 Side turn indicator Open circuit or shorted to supply DTC is found not active. DDM-DD11 Communication with switch pack Internal Fault DTC is found not active. DDM-DD10 Communication with control module Internal fault DTC is found not active. DIM-E003 Configuration fault Software fault DTC is found not active. ECM-1517 Turbo control - Pressure too high DTC is found active. ECM-580F Engine control module (ECM) - Signal missing DTC is found not active. ECM-7600 Immobilizer - Signal missing DTC is found not active. ECM-928C Cruise controll - Faulty signal DTC is found not active. ECM-952F Accelerator pedal sensor - Faulty signal DTC is found not active. ECM-9530 Accelerator pedal sensor - Signal missing DTC is found not active. ECM-A600 Additive dosing module (ADM) - Faulty signal DTC is found not active. ECM-E010 Configuration fault - Qualifier unknown DTC is found not active. EPS - No fault found GPS - No fault found lAM - No fault found ICM-1A58 Communication with global positioning system module (GPS) Signal missing DTC is found not active. MMM - No fault found PDM - No fault found PHM-E010 Power supply Faulty signal DTC is found not active. SRS-0004 PAD lamp Signal missing DTC is found not active. SRS-0005 Battery power supply Low voltage DTC is found not active. SRS-009A Rear belt buckle Signal missing DTC is found not active. SRS-0129 CAN signal Signal missing DTC is found not active. SRS-012A CAN signal Signal missing DTC is found not active. SRS-012D CAN signal Signal missing DTC is found not active. SWM-0A10 Communication between control units Signal missing DTC is found not active. SWM-0A11 Communication between control units Signal missing DTC is found not active. TMC - No fault found TRM-E010 Power supply Too high voltage difference DTC is found not active.
  4. Salut Am cam de un an urmatoarea eroare: "Stabilitätskontrolle erfordert Wartung - Verminderte Motorleistung". Practic raman fara putere la masina si trebuie sa trag pe dreapta, sa opresc motorul, iar la repornire totul e ok. La inceput se intampla doar in sarcina, cam la 3000 rot/min, acum imi apare si cand parchez masina. Multumesc anticipat!!!
  5. Furt oglinda
    Salutare, Azi dimineata m-am trezit fara oglinda de la sofer. Nu am sunat la politie, fiindca nu cred ca are rost. Am sunat la Volvo si mi-au facut oferta de 2750 lei pentru tot, dar mi-i se pare exagerat. Daca cumva, stiti pe cineva sau de unde pot lua la dezmembrari o oglinda, va rog sa-mi spuneti. Am un Volvo V50 1.6, an 2007. Calin
  6. Furt oglinda
    Vreau sa-mi cer scuze celui pe care l-am acuzat pe nedrept. In virtutea celor intamplate, am scris la cald, ce am simtit atunci. Nu stiu cine utilizatorul de pe forum, dar a citit mesajul initial si sigur nu i-a cazut bine. La el am gasit oglinda model 2008. Eu inca caut oglinda, sa se potriveasca. Acum stiu ce am nevoie, doar ca nu gasesc modelul respectiv. Acum doar ca lamurire pentru cei ce vor sa stie: - modelul 2005, 2006 are oglinda cu semnalizare mica si mata - modelul 2007 (tot fara facelift) are oglinda cu semnalizare mare si clara (aproape ca 2008, dar cu capac 2006) - modelul 2008, 2009 are oglinda cu semnalizare mare si clara (dar cu capacul cu o anumita scobitura) Cele de la ionutz_lup nu raspund la comenzi (fiind model 2005). Am gasit una in Germania si o voi lua la risc, dar macar seamana cu ce am eu nevoie.
  7. Furt oglinda
    550 mi-a cerut.
  8. Furt oglinda
    Revin cu o lamurire cu privire la neanuntarea politiei. Un prieten in Cj a trecut prin experienta similara, iar cei de la politie doar au albit masina si l-au amprentat pe proprietar. Cam atat si asa a si ramas. Cred ca stiti toti cum e cu timpul disponibil si mai ales cu asteptatul pe la cozi, ca sa nu rezolv nimic. Acum va povestesc unul din telefoanele mele de ieri in cautarea oglinzii. Am inceput sa sun la dezmemebrari, impreuna cu cativa prieteni si doi am sunat la acelasi numar in B. Eu am fost neinsipirat sa spun ca mi-a fost furata oglinda. Ambele telefoane au fost in decurs de 5 min. Individul care avea diverse culori si modele pentru Volvo V50, nu mi-a mai raspuns ulterior la telefon. Probabil din cauza ca am pomenit ca mi-i s-a furat. Poate exagerez eu, dar concluzia la care am ajuns, e ca individul le "produce". Multumesc tuturor pentru sfaturi, mai ales lui iD-entity si N3cks. Sper doar sa gasesc intr-o suma rezonabila. Poate daca as fi avut CASCO nu era problema, dar.... Am vb cu ionutz_lup si iau de la el.
