kelyoss
    75
9 Neutral
1 Follower
About kelyoss
  • Locatie Bucuresti
  • Auto Volvo S60 T5
  • Fabricatie 2001
  • Auto 2 XC 90 2,5T
  • Fabricatie 2 26
1,537 profile views
  1. daca nu este din mufa trebuie sa schimbi partea respectiva , asa am patit si eu la mine nu mergea partea superioara din dreapta . Daca vrei eu am partea stanga (din dezmembrari ) am cumparat alt ansamblu si am folosit doar dreapta si afisajul
  2. S60 BI-FUEL de fabrica (GPL)
    din cate am citit volvo bi-fuel foloseste CNG nu LPG, uite care este diferenta : Compressed Natural Gas or CNG is stored on the vehicle in high-pressure tanks - 20 to 25 MPa (200 to 250 bar, or 3,000 to 3,600 psi).  Natural gas consists mostly of methane and is drawn from gas wells or in conjunction with crude oil production.  As delivered through the pipeline system, it also contains hydrocarbons such as ethane and propane as well as other gases such as nitrogen, helium, carbon dioxide, sulphur compounds, and water vapour.  A sulphur-based odourant is normally added to CNG to facilitate leak detection.  Liquefied Petroleum Gas or LPG (also called Autogas) consists mainly of propane, propylene, butane, and butylene in various mixtures.  It is produced as a by-product of natural gas processing and petroleum refining.  The components of LPG are gases at normal temperatures and pressures.  One challenge with LPG is that it can vary widely in composition, leading to variable engine performance and cold starting performance.
  3. Puntea pe spate
    daca nu trage de ce sa pui tractiune spate (AWD) !
  4. ne  bucuram ca ai ajuns cu bine (Sorin )
  5. cam greu de dat de tine, ne vedem sambata sa schimb uleiul la cutie (aisin), am vb cu vadim vin pe la 15, daca ai timp mai devreme anunta-ma. am luat ulei 16 litri  ;)
  6. putem vorbi la telefon ? nr meu : 0744220364
  7. Recomandare boxe și head-unit
    asa o fi bine ? yatour incorporat + usb charger (3 X 1,5 amp) + aux in . Cu  grija este posibil .
  8. Sticla Far S60
    poti sa dai si tu mai multe detalii ? am vaut far asa pe un forum , este OM sau un kit ? mersi.
  9. Problema lumini bord
    si dupa diagnoza crezi ca se repara singura ?
  10. Salut
    daca e benzinar ?
  11. Sticla Far S60
    asta nu este far de 2001 si nici bara (asa scrie in semnatura), ai facut si alte modificari ? sau merge " plug and play "
  12. Problema sistemul de franare!
    ceva asemantor am patit si eu , la mine parca fugea/vibra toata fata, problema: lipsa vaselina planetara spre cutie
  13. de ce nu raspunzi la telefon ? nu mai sunt ok numerele ?
  14. LED-uri in loc de becuri la iluminare bord
    asa arata cu led RGB cu telecomanda (de pe masina mea) VIDEO0029.3gp
  15. Sticla Far S60
    pai cum facem sunt foarte interesat (da un bip 0744220364 )
