Alexanderfg
    15
2 Neutral
About Alexanderfg
  • Locatie Bucuresti
  • Auto Volvo S40 II 2008 1.6 D
  • Fabricatie
  • Auto 2 Cart lemn 4 rulmenti.
  • Fabricatie 2 15
560 profile views
  1. La multi ani Alex (Midnight Caller)!
    Bine  uite si in bash  iti cant  #!/bin/bash   output='' for i in {1..4} do   output=$output"Happy birthday "     if [ $i -eq 3 ]   then     output=$output"dear $1\n"   else     output=$output"to you\n"   fi done   echo -e $output  stdin copy   Standard input is empty  stdout copy   Happy birthday to you Happy birthday to you Happy birthday dear Midnight Caller Happy birthday to you
  2. La multi ani Alex (Midnight Caller)!
    c++: cout<<"Happy Birthday [MidnightCaller]"<<endl;   Basic: WriteToConsole "Happy Birthday [MidnightCaller]"   Java /* package whatever; // don't place package name! */ import java.util.*; import java.lang.*; import java.io.*; /* Name of the class has to be "Main" only if the class is public. */ class Ideone {     public static void main (String[] args) throws java.lang.Exception     {         System.out.println("HappyBday [MidnightCaller]");     } }   C#: Console.writeline("Happy Birthday [MidnightCaller]");   PHP: echo "Happy Birthday [MidnightCaller]"   C: Console.writeline("Happy Birthday [userName]");   PowerShell:  % {if ($_ -ne 2) {Write-Host "Happy Birthday to You!"} else {"Happy Birthday MidnightCaller"}}   La multi ani Musiu ! Sa fii vesnic si mereu Tu ! ai pup iu  xoxo :)))
  3. Achizitie C30 1.6 drivE
    Ps: am vazut undeva ca intretinerea e anormal de scumpa. nu Volvo daca vrei sa ai si vrei sa il intretii e scump. eu personal nu renunt la Volvolino nici daca dau inca juma de gholf getei in plus.  Stiu ei cine sunt cei pe care ii stresez cu pepsi, mop, gura mare, sandwichuri si voie buna
  4. Achizitie C30 1.6 drivE
    Turbo ! Keep it up ! eu sunt la a doua. dar 1.6 d-ul meu facut de stiu ei cine MEEEERGE si sunt nesimtit de neserios cu el Merge si merge si trage si merge  dar sfat, NU lua 1.6 d  Saliu Alex
  5. ANTI-SKID SERVICE REQUIRED
    Salut,  ma bag si eu in seama DPF OFF scurt si la obiect, facut cum trebuie ! asta cam off topic  cat despre anti skid, la mine la - ceva grade apare in bord, ii dau cald la motor, merg, start/stop si isi da "self heal" vba unui Guru  stie el cine  n-am dureri de cap, nu mai schimb filtre, masina nu scuipa fum happy camper ps: nu mai iau curbe cu 140 si nu mai merg cu 180 cu 1.6 d  Noroace
  6. ANTI-SKID SERVICE REQUIRED
  7. ANTI-SKID SERVICE REQUIRED
  8. ANTI-SKID SERVICE REQUIRED
  9. ANTI-SKID SERVICE REQUIRED
  10. ANTI-SKID SERVICE REQUIRED
  11. Salut, Sigur ca da. e ok  Pentru cine mai are nevoie de informatii am gasit in engleza am facut legatura si am invatat. Info prezentat in bord este OK. Mai jos aveti printuri poate va ajuta. stiu ca e off topic dar if it helps Zi faina
  12. Salut, scuze   oricum mersi,  ideea e ca nu stiu daca mere  diseara sper sa ajung pana la voi mor de draci cu oglinda aia   sa vezi ce frumos arata partea dreapta
  13. Salutare,    revin cu informatii despre evenimente. 1. Vreau sle multumesc lui MidnightCaller si lui Alex pentru faptul ca sunt cei mai seriosi si profesionisti cu care am avut minunata placere sa colaborez. masina a stat aproape o luna la reparat ( din lipsa de bani du din lipsa lor de actiune) am incercat regenerari etc. filtru dpf mort.  asadar Filtru scos, soft rescris, sorb si uleti + filtre schimbate, diagnoza completa si masina Urla ! in sensul cel mai bun  doar ca vineri noapte dupa ce m-am bucurat de ea, a intrat un nea gigi cu un camion in mine, rupta oglinda dreapta, atinsa toata laterala dreapta mai putin aripa fata.  dar de mers rupe am aflat de la ei ca am webasto pe masina, am incercat azi sa il pun in functiune si dupa ce opresc motorul am mesajul din poza de mai jos. any clues ?  Concluzionand, Multumeesc mult baieti pentru ca mi-ati reinviat masina si sunt extrem de multumit.  PS; Daca are cineva o oglina de volvo s40 facelift 2008 dreapta sau stie mai ieftina de 750 ( care e super mult ) la dezmembrari raman recunoscator.  am si oglinda veche si cred cumva ca ar putea fi reconditionata dar e bataie de cap. atasez poza cu eroare de webasto
  14. Salut,  In primul rand doresc sa va multumesc. Nu reusesc sa ajung decat dupa orele 18:00 si doar in zona Bucuresti, nu pot iesi din buc, Nu am mers foarte mult cu check engine, sa aprins la plecare vineri spre piatra neamt si m-am intors asa cu el deci aprox 700 km. In rest erorile au fost mereu resetate a avut momente cand sa comportat ok. Masina cand am cumparato am pus pe tester si totul era ok in afara de un bec de pozitie defect, apoi a inceput haosul.  As vrea sa o aduc la voi sau la Bogdan dar timpul si distantele nu imi permit acest lucru, daca pot veni astazi dupa 18:00, si ai putea sa imi lasi un PM cu nr tau de telefon, Midnight Calle, as ramane indatorat. Nu am vrut sa creez discutii aiurea, si da, masina o am de doua luni, nu de una, si nu nu ma pricep deloc la ele, e luata de la un prieten care nu a avut probleme cu ea. conduc de foarte multi ani diferite feluri de masini. Eroare pe care clar am vazuto la ultima testare in afara de nu stiu ce erori ("pe la electrica' ") cum mi-a zis 'nea mesteru de acolo e Filtru de particule infundat/defect, regenerare incercata in mai multe moduri si esuata.  Chiar as vrea sa conduc aceasta masina insa nu mai vreau sa dau cu banii la tot felul de "specialisti" pentru ca realmente nu mai am resursele financiare necesare.    Va multumesc mult si va doresc sa aveti o zi buna Alex
