gheorghe ivan
locatie"camshaft solenoid valve"
buna ziua va rog sa-mi spuneti unde este localizata valva electromagnetica ax cu came"camshaft solenoid valve" la volvo s40
fabricat 2003 /1783 cmc/90 kw
va multumesc
va multumesc
Se afla sub capacul de plastic de pe motor unde sunt si fisele pt. bujii.Atasez foto cu locatia si piesa respectiva.
Se numeste camshaft reset valve si este unde a zis Sandro .
Nu prea se strica insa acea piesa .
va multumesc pentru informatie la diagnoza pe tester a aparut eroare"valva electromagnetica ax cu came blocata pe deschis"si pe tester cu meniu in engleza"camshaft solenoid valve stuck on"
Nu exista astfel de eroare la Volvo S40/V40, asta e o inventie de eroare .
Exista numai 16 erori legate de reset valve :
folder.gifECM-5D Camshaft reset valve. Signal missing. Intermittent fault
folder.gifECM-5D Camshaft reset valve. Signal missing. Permanent fault
folder.gifECM-5D Camshaft reset valve. Signal too high. Intermittent fault
folder.gifECM-5D Camshaft reset valve. Signal too high. Permanent fault
folder.gifECM-5D Camshaft reset valve. Signal too low. Intermittent fault
folder.gifECM-5D Camshaft reset valve. Signal too low. Permanent fault
folder.gifECM-5E Camshaft reset valve. Faulty signal. Intermittent fault
folder.gifECM-5E Camshaft reset valve. Faulty signal. Permanent fault
folder.gifECM-5F Camshaft reset valve. Faulty signal. Intermittent fault
folder.gifECM-5F Camshaft reset valve. Faulty signal. Permanent fault
folder.gifECM-60 Camshaft reset valve. Faulty signal. Intermittent fault
folder.gifECM-60 Camshaft reset valve. Faulty signal. Permanent fault
folder.gifECM-61 Camshaft reset valve. Faulty signal. Intermittent fault
folder.gifECM-61 Camshaft reset valve. Faulty signal. Permanent fault
folder.gifECM-62 Camshaft reset valve. Faulty signal. Intermittent fault
folder.gifECM-62 Camshaft reset valve. Faulty signal. Permanent fault
De curiozitate ce gunoi de tester a fost folosit ?
Edited by Bogdan G
