Posted 15 Sep 2011 · Report post Cumparata in primavara, ca noua. totul original pe ea, nicio modificare. maxim 200km parcursi, 100 % sosea. marime cadru : 17, culoarea rosie,ca in poza. nu i-am mai facut poze deoarece, cum am mai zis, este aproape noua. Vine insotita de carti si manuale + actele de achitizie.FrameSpecialized A1 Premium Aluminium, fully butted, formed TT, Double ORE DT, externally relieved HT, reinforced disc mount, forged dropouts w/ replaceable hanger, disc onlyForksSR Suntour SF10-XCT-V2D-MLO, 80mm, 1pc. alloy lower, 28mm Hi-Ten stanchions, mechanical LO, coil/mcu spring w/ preload adj., size-specific spring rates, spring assisted seals, disc onlyRear DerailleurSRAM X-4, mid cageFront DerailleurShimano Altus, 34.9mm clampShiftersSRAM X4-R triggerChainsetCrank Set: SR SunTour, Octalink spline Chainwheels: 42S x 32S x 22S replaceableBottom BracketShimano BB-ES25, Octalink spline, cartridge bearing, 68mm x 118mmChainKMC X8 w/ reusable Missing LinkFreewheelSRAM PG-820, 8-speed, 11-32tHeadset1-1/8" threadless, loose ballStem3D forged alloy, 10 degree rise, 25.4mm clampHandlebarsAlloy riserbar, 25mm rise, 640mm wide, 8 degree back sweep, 7 degree up sweepFront BrakeAvid BB5, mechanical disc, 160mm G2 Clean Sweep rotorRear BrakeAvid BB5, mechanical disc, 160mm G2 Clean Sweep rotorBrake LeversAlloy, linear pullRimsAlex RHD, 26", pinned, alloy double wall, 32h front and rearFront HubForged alloy, hi/low flange, double sealed, ground race, machined disc mount, 32hRear HubForged alloy, double sealed, ground race, machined disc mount, cassette, 32hSpokes2mm (14g) stainlessTyresSpecialized Fast Trak LK Sport, 26x2.0", 60TPI, wire beadSaddleSpecialized XC, Body Geometry, 143mm width, front and rear bumpersSeatpostAlloy two bolt, 12.5mm offset, micro adjust, 30.9mm Seat Post Clamp / Binder: Alloy QR, nylon washerPedalsSteel cage, composite body, 9/16"GripsSpecialized Enduro, dual compound Kraton, no flange, 131mmMiscellaneousChain stay protector, reflectors, clear coat, owners manual se poate vedea/testa in Bucuresti Pret 1500 ron o733 524 959 Share this post Link to post Share on other sites
