danutttz
Vand Calculator
7 posts in this topic
Placa de baza: asus p5k-v
Specificatii tehnice:
Cod producator: P5K-V
Cod PC Garage: 19705
Garantie tehnica: 36 luni
Garantie de conformitate: 24 luni
General
Format ATX
Soclu procesor 775
FSB 1333/1066/800 MHz
Model chipset Intel G33/ICH9
BIOS 8 Mb Flash ROM
AMI BIOS
PnP, DMI2.0, WfM2.0, SM BIOS 2.3, ACPI 2.0a
Procesoare suportate Intel Core 2 Quad/Core 2 Extreme/Core 2 Duo/Pentium Extreme/Pentium D/Pentium 4
Interfata grafica PCI Express x16
Raid RAID 0,1 and JBOD
Model placa video Intel Graphics Media Accelerator 3100
Maximum shared memory of 256 MB
Placa audio integrata Realtek ALC 883
Placa retea integrata PCIe Gb LAN controller featuring AI NET2
Numar IDE 1 x ATA 133/100/66
Numar SATA 4 x SATA-II
1 x eSATA
Altele 6x USB 2.0 aditionale
Intelligent overclocking tools
Precision Tweaking
SFS
ASUS C.P.R.
Supports CrossFire Technology
Memorii Suportate
Memorie maxima 8 GB
Sloturi
PCI 2 x PCI-E x16
1 x PCI-E x1
3 x PCI
Hard disk: Western Digital HDD Caviar SE16 640GB (WD6400AAKS)
Cod produs: WD6400AAKS
Capacitate: 640 GB
Viteza de rotatie: 7200 rpm
Buffer: 16 Mb
Interfata: SATA 2
Rata de trasfer: 300 MB/s
Dimensiuni: 147 x 101.6 x 25.4 WxLxH(mm)
Greutate: 0.630 Kg
Procesor: Intel® Core™2 Duo Processor E4600(2M Cache, 2.40 GHz, 800 MHz FSB)
Status Launched
Launch Date Q4'07
Processor Number E4600
# of Cores 2
# of Threads 2
Clock Speed 2.4 GHz
L2 Cache 2 MB
Bus/Core Ratio 12
FSB Speed 800 MHz
FSB Parity No
Instruction Set 64-bit
Embedded Options Available No
Supplemental SKU No
Lithography 65 nm
Max TDP 65 W
VID Voltage Range 0.8500V-1.5V
Placa video: Ati radeon x1300/1550
Ram: 256
Soclu: PCI Express x16 2.0
Memorie ram: 2 x 1Gb Kingston 1066 mhz
DWD-Rw Samsung
Sursa: Sursa RPC PWPS-500WTG-AU01A
Cod producator: PWPS-500WTG-AU01A
Cod PC Garage: 277987
Garantie tehnica: 24 luni
General
Tip ATX
Putere 500 W
Numar ventilatoare 1x 120 mm
Conectori 1 x 20 pin ATX
1 x 4 pin ATX 12V
3 x SATA
2 x 4pin Molex
Eficienta 75 %
Dimensiuni 150 x 139 x 86 mm
Protectii OVP, OPP, SCP
Carcasa Delux MF858
Sistemul este folosit maxim 2 luni merge impecabil are instalat windows 7.......Pe langa sistem mai primiti si un memory stick de 16 gb Kingston Data travel........
Pret 800 Ron
Telefon 0786748538
Am uitat sa precizez ca pretul include si monitor Likom de 17 inch
Nu vrei sa il dai pe piese? :)
Bine, multumesc! :)
Spor la vanzare!
