MAIDRAGA
Coduri erori
27 posts in this topic
Salut
Luni dimineata m-am programat la Volvo Cj pentru update de soft si eventual o diagnoza.
Intre timp am facut rost de o mufa bluetooth OBD II, am instalat aplicatia torque pe tableta sa pot citi coduri daca am. Am gasit 8 coduri:
P1577
P2585
U0405
P193b
P1187
U300b
U0167
P0234
Daca cineva ma paote ajuta sa fiu pregatit pe cand ajung la Volvo, va rog nu ezitati.
Sint generice si nu pot corespunde intru totul cu cele de Volvo.Daca mergi la reprezentanta ,le afli acolo in clar cum li se zice ,fiecareia pe care o vor gasi.Pe "gongle" se gasesc ce ai postat tu daca vrei sa iti faci asa idei
Edited by V50Saphir
Am fost azi la Volvo. Am o lista de erori de la 48 incoace.
Dupa update-ul de soft facut azi si cu masina in proba( cu ei) nu au mai aparut, dar ma indoiesc ca problema de presiune la turbo va disparea peste noapte.
Control Module - Diagnostic Trouble Code
Status
ADM
No fault found
AUD
No fault found
BCM-0101
Communication between control units
Communicational problems with ECM
DTC is found active.
CCM-0060
Damper motor, defroster Internal fault
DTC is found not active.
CCM-0062
Damper motor, temperature left Internal fault
CCM-DD15
Damper motor, temperature left No communication
CCM-DD16
Damper motor distribution No communication
CCM-DD31
Damper motor, recirculation. No communication
CCM-DD32
Damper motor, temperature right No communication
CCM-DD33
Damper motor, defroster No communication
CEM-4C01
Ambient temperature sensor Signal too high
CEM-4F33
Battery Temperature Faulty Signal
CEM-8A12
Low beam left Faulty signal
CEM-8F22
Wiper motor module (WMM) Voltage too low
CEM-DF11
CAN-H, high speed network Signal missing
CEM-4C02
Ambient temperature sensor Signal too low
CEM-DE43
Communication with DOM control module Signal missing
CEM-6C15
Double lock, left rear door Lock failure
CPM-4001
Auxiliary heater Activated too long
DDM-6E03
Mirror motor Open circuit
DDM-6E0S
DDM-6E0C
DDM-8003
Mirror heater Open circuit or shorted to supply
DDM-8022
Side turn indicator Open circuit or shorted to supply
DDM-DD11
Communication with switch pack Internal Fault
DDM-DD10
Communication with control module Internal fault
DIM-E003
Configuration fault Software fault
ECM-1517
Turbo control - Pressure too high
ECM-580F
Engine control module (ECM) - Signal missing
ECM-7600
Immobilizer - Signal missing
ECM-928C
Cruise controll - Faulty signal
ECM-952F
Accelerator pedal sensor - Faulty signal
ECM-9530
Accelerator pedal sensor - Signal missing
ECM-A600
Additive dosing module (ADM) - Faulty signal
ECM-E010
Configuration fault - Qualifier unknown
EPS
No fault found
GPS
No fault found
lAM
No fault found
ICM-1A58
Communication with global positioning system module (GPS) Signal missing
MMM
No fault found
PDM
No fault found
PHM-E010
Power supply Faulty signal
SRS-0004
PAD lamp Signal missing
SRS-0005
Battery power supply Low voltage
SRS-009A
Rear belt buckle Signal missing
SRS-0129
CAN signal Signal missing
SRS-012A
SRS-012D
SWM-0A10
Communication between control units Signal missing
SWM-0A11
TMC
No fault found
TRM-E010
Power supply Too high voltage difference
Mai draga, daca tot te-am prins pe aici, la intalnirile de la Cluj de ce nu te prezinti? :)
Uit sa intru pe forum, cu lunile. Desi am cont, cum nu sunt un obisnuit al forumului, intru doar cand imi aduc aminte ca exista aceasta comunitate si membrii cu aceleasi probleme ca ale mele.
Cat te-o costat updateul? Si cat timp o durat?
Sent from my X551
Indivizii de la Cluj mi-au comunicat faptul ca nu fac update de soft doar ca asa vreau eu. Ca atare nici un pret pt asta nu mi-au spus. Mi-au facut totusi o oferta, in urma cu mai mult de un an, o revizie generala la ei si primesc update cadou.
Salutare baieti! Sper sa nu postez gresit, am vazut ca aici sunt doar coduri de erori dar m-am gandit ca poate pot pune si mesajele de pe CB de eroare...
Am si eu doua mesaje de eroare pe care nu reusesc sa le traduc, poate ma puteti ajuta voi.
1) ANTI-SKID TIJDELIKT UIT
2) LAADSYSTEEM SERVICE SPOED
Va multumesc anticipat!
1. Antiskid service required
2. power system service urgent .
Mai mult ca sigur masina nu mai porneste si face click, clonk .
Si mai sigur e un 1.6D cu alternator defect .
Zic bine ?
Cred ca zici perfect, intradevar nu mai porneste. dar nu stiam ca este datorita alternatorului. Momentan nu sunt in Bucuresti dar da, astea sunt simptomele masinii. Doar de la alternator sa faca asa? Mentionez ca erau destul de multe "beculete" aprinse pe bord.
Codul erorii spune cite ceva ,deci nu este o filosofie si mai cu seama ca ,daca sint probleme acelea sint la 1,6D cele mai constante .Daca nu ai tensiune corecta pe baterie este din incarcare alternator ,etc.Poate fi si o invitatie sa mergi sa iti testeze el masina,tu nestiind despre ce este vorba :smile: .Poate mergi si o zi ,doua cu V70 cine stie ca defectele sint defecte... :smile:
Edited by V50Saphir
P0089 NU are treaba cu suction valve ci :
P0089
ECM-2520
Fuel pressure
Pressure too low
P0089
ECM-2540
Fuel pressure
Pressure too high
Iar P2458 este
P2458
ECM-2A40
Particle trap
Overloaded
Edited by Midnight Caller
Mersi mult, midnight  caller....deci inseamna ca am filtru de particule plin? In bord nu mi se aprinde nici un martor si nici un mesaj de eroare...ar fi nevoie de o regenerare fortata?..am 84000 de km si pacatosul motor de 1.6D ...
Sunt in Italia si aici mecanicii merg pe ghicite...tot schimbi pe piese pana nimeresc...ma gandeam ca poate ee un senzor si reusesc sa il schimb eu
Poate fi orice de la DPF infundat pana la furtunasele de presiune sparte, senzor presiune defect, firicel rupt, etc...
O sa ma duc in seara asta la mecanic si o sa va tin la curent...poate o sa fie de folos cuiva pe viitor
salut am si eu un vida dice diagnose si i-am dat o diagnoza si imi apar urmatoarele erori ma poate ajuta cineva va rog ?
masina : volvo s40 2.0d diesel
bcm-0115 communication between control units communication problems
cem-6c05 central lock, driver door lock failed ( aici am probleme cu usa sofer nu se inchide din cheie..doar manual cu cheia nu stiu ce sa ii fac)
cem-6f83 dimmer faulty signal
ecm-0097 intake air temperatur (IAT) sensor inlet signal too low
ecm-0380 glow plug relay faulty signal
ddm-6c09 central locking motor m3 stuck in inactive position
ecm-0605 engien control module (ecm) internal fault
Te duci pe Initial State, dai dublu-click pe eroare si iti explica exact ce vrei tu sa afli.
PAI SI CUM POT REZOLVA ERORILE ACELEA ?..AM IDENTIFICAT CATEVA DIN ELE
si daca am probleme cu ceva piese..nu stiu cum sa le gasesc..
de exemplu la prima eroare bcm-0115 .. imi spune ceva ca nu comunica transmisia cu dstc..
Edited by ma0914d
Aia o ignori si o stergi, la 7 din 10 masini am gasit eroarea asta,.
Salut! Ma bucur ca am dat de un forum ca acesta! :) Am si eu o mica nelamurire. Am un Volvo V50 R Design , an fabricatie 2008 , motor 2.0 diesel. In mai,anul acesta,i-am facut revizia. Totul ok pana acum o saptamana,cand mi-a aparut in bord mesajul "motorsystem wartung erforderlich" (necesar revizie motor)... Am mers la dealerul de un am luat masina,i-au facut un test si mi-au zis ca nu au gasit nimic neregula si nu stiu sa-mi zica din ce cauza a aparut mesajul respectiv (este acelasi dealer unde am facut si revizia). M-au sfatuit sa merg la o reprezentanta Volvo sa vada ei despre ce este vorba... Aici ma cam tem de costuri,deoarece un simplu test la automobil,in Germania costa destul de mult!... Din ce cauza credeti ca a aparut acel mesaj? Este ceva ce sa ma ingrijoreze mult? Ar fi ok sa merg totusi la un test?... Multumesc frumos! :)
Trebuie sa mergi la cineva care știe Volvo. Fără sa știm ce cod de defect ai nu putem da te ajutam .
...Am inteles! Multumesc frumos! Nu stiu ce cod este... Vad numai mesajul in bord.... O cunostinta mi-a zis ca poate fi vorba de faptul ca in ultimile 3 saptamani nu am prea rulat cu masina cine-stie-ce,si fiind diesel... :)
