renascentist
vand ETM pentru clapeta acceleratie
vand ETM (electronic contactless sensor position/ sensozor pozitie) pentru volvo V70/ c70/ s60/ s70/ s80 XC pentru clapeta de acceleratie
l-am comandat din anglia acum o saptamana si nu l am mai folosit
pret 400 ron
" The original ETM Magneti Marelli throttle position sensor which is mounted on the housing on these models wears out in time due to the friction generated and general wear and tear. Normally the TPS is not available separately and a new throttle body is required which will prove to be very expensive but we have the option to replace the old style potentiometer TPS with an electronic contactless unit. The advantages of fitting this unit are. A significant saving in costs and the new contactless TPS has a much longer life as there are no moving parts. It is also more stable for better performance. Instructions Included. "
