Posted 14 May 2009 · Report post BUNA ZIUA DOMNILOR POSESORI DE VOLVO.AM O MARE NELAMURIRE,SIGUR CINEVA A MAI TRECUT PRIN ASTA SI POATE SA IMI IMPARTASEASCA. AM UN VOLVO V40 DIESEL,FRUMOASA MASINA,INSA DE CURAND AUD UN HURUIT GROAZNIC IN MASINA,O DUC LA MECANIC SI ZICE CA E RULMENTUL PE SPATE DREAPTA,IL COMAND SI IL SCHIMBA BAIETII,ASEARA VIN ACASA DAR SUNETUL NU DISPARE ,ACELASI HURUIT,IN SPECIAL CAND E IN A DOUA SI SE FRANEAZA SAU CAND DAU CU SPATELE SI NU APAS AMBREIAJUL,PLUS DE ASTA IN A DOUA DACA ACCELEREZ CONSATNT PNA PE LA 3200R/MIN REALIZEZ CA MOTORUL PARCA SE INEACA,ADICA TRAGE SACADAT.CE PUTETI SA IMI SPUNETI DE ASTA?LE-AM EXPLICAT MECANICILOR SIMTOMELE MASINII,EI ZIC CA E TRAVERSA DIN FATA DE SUB PUNTE,CA ATINGE UN PIC SI DE LA VIBRATII HURUIE ASA......MIRA-MA-S ,EU CRED CA MECANICII EXISTA SA DEPISTEZE O PROBLEMA APARUTA LA MASINA SI ACTIONAT SI SCHIMBAT PIESA IN CONSECINTA.LE-AM ZIS SPUS TOATE ACESTE SIMTOME DAR NU M-AU LAMURIT SAU CONVINS DE LOC.POATE AM MAI MULT NOROC AICI PE FORUM CA AM VAZUT CA INTR-ADEVAR SUNT OAMENI PRICEPUTI SI CUNOSCMECANICA.O ZI BUNA LA TOATA LUMEA Share this post Link to post Share on other sites
Posted 14 May 2009 · Report post 1). Multi au schimbat rulmentii degeaba din cauza huruitului... CAUCIUCURILOR2). Traversa intr-adevar poate vibra si atinge de cadrul motor, e problema destul de des intalnita, si cativa colegi forumisti au patit asta.3). Trasul sacadat al motorului poate fi din mai multe cauze, de la furtune sparte pana la valva de control turbina pe duca sau injectoare/pompa care nu mai merg in parametri.4). Ceva erori pe tester ? Share this post Link to post Share on other sites
Posted 19 May 2009 · Report post maine o duc la doctor-reprezentanta volvo sa imi dea o diagnosticare,oricum multumesc de sfaturi. Share this post Link to post Share on other sites
