Posted 14 Oct 2009 · Report post Ma intereseaza de unde pot face rost de un manual de 460 din 1997?Am probleme cu imo si vreau sa vad daca pot sa il anulez. Share this post Link to post Share on other sites
Posted 14 Oct 2009 · Report post Uite aici http://www.volvo-club.ro/forum/index.php/topic,4713.0.html .Nu cred ca ai sa gasesti in manual cum poti anula imobilizatorul , mai degraba la reprezentanta . Share this post Link to post Share on other sites
Posted 15 Oct 2009 · Report post Daca ai telecomanda incearca sa o reprogramezi. Posibil ca asa se va rezolva problema cu imobilizatorul.Succes! Share this post Link to post Share on other sites
Posted 15 Oct 2009 · Report post Salut,Daca te ajuta am instructiunile de programat alarma Volvo Guard 1 .. in germana. Share this post Link to post Share on other sites
Posted 15 Oct 2009 · Report post Salut,Daca te ajuta am instructiunile de programat alarma Volvo Guard 1 .. in germana.Si eu in engleza dar nu stiu cit ajuta la imobilizator . If the alarm works of the remote control which also works door locks you could try re-programming it.programming.Access underbonnet daignostic unit.Insert selector cable into socket 1.lock and unlock vehicle using remote control.switch ignition on .press test button 4 times.check LED illuminates.program remote control as follows.press test button 3 times.check LED illuminates .press test button 4 times.check LED illuminates.press test button 4 times.check LED illuminates.press unlock button on remote control.if a second remote is to be programmed , do the same again but increasefinal sequence by 1. Share this post Link to post Share on other sites
Posted 15 Oct 2009 · Report post Eu ziceam de unitatea centrala nu de telecomanda.Poate este vreo setare acolo care te poate ajuta.Din pacate nu am decat in germana. Daca-ti face trebuinta scanez si-ti trimit. Share this post Link to post Share on other sites
