Guest S40
Rechemari la service pentru S/V40
3 posts in this topic
This affects:
S70, V70, C70 models 1997 - 2000
S40, V40 models 1998 on (See below)
A ticking noise may be heard from the canister purge valve. The noise increases in cold weather. Volvo have introduced a rubber-covered clamp that dampens the noise. On cars from year 1998/99 with turbocharged engines, the canister purge valve must also be replaced.
If your car has this problem then contact a Volvo dealership.
S40/V40 models 1998 on
ENGINE MODEL YEAR CHASSIS NO
B4xx4T              1998/9              130000 - 414999
B4xx4S2              2000              415000 -
B4xx4T2              2000              415000 -
Ce este "canister purge valve" si unde e localizata?
S-a confruntat cineva cu asa ceva?
Eu am mai multe zgomote neidentificate asa ca.....it maybe the case!
Multam,
Mihai
This affects:
Multam,
Mihai
